winterdd Posted June 19, 2019 Share Posted June 19, 2019 so i have a loft area in my tiny home and i have the walls stopping below. however, even after remaking the roof, the ceiling acts as if the walls are ballooning thru. how can i make the drywall remove the gaps in the ceiling? thanks! cant find anything on this issue. Link to comment Share on other sites More sharing options...
Chrisb222 Posted June 19, 2019 Share Posted June 19, 2019 Just a guess, but you might have some automatically generated invisible attic walls up in the loft. Go to the attic level and see...? Without looking at the plan that's all I got. Link to comment Share on other sites More sharing options...
winterdd Posted June 20, 2019 Author Share Posted June 20, 2019 hmmm, no walls in attic level. that being said, when dealing with a loft, how can i create the subflooring for the loft without creating a second floor? i tried creating a new level (2nd floor) and it messes the roof up of course. it's like i only need the floor level with no walls. Link to comment Share on other sites More sharing options...
winterdd Posted June 20, 2019 Author Share Posted June 20, 2019 selby.plan Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 20, 2019 Share Posted June 20, 2019 1 hour ago, ChiefUserBigRob said: hmmm, no walls in attic level. that being said, when dealing with a loft, how can i create the subflooring for the loft without creating a second floor? i tried creating a new level (2nd floor) and it messes the roof up of course. it's like i only need the floor level with no walls. fixed a few things for you... set level 0 floor defaults to slab on grade set level 1 floor defaults to 90-1/8", this is to get your plate height to nominal 8' ceilings with a 2nd floor set exterior walls to balloon through framing (now plate height is correct) set foundation to auto-build set roof defaults to lower ridge board size and be contained within the ceiling planes set roof to auto build aligned patio walls with exterior walls built second floor with finished ceiling height of 1/8" set 2nd level floor defaults to 2x6 floor framing lumber drew a room divider, set 1 room to open below, set other room with no flat ceiling above set room divider to hang platform etc. rebuilt floor and ceiling framing.. you may need to re-build wall framing you may need to adjust heights, roof etc...do this in floor defaults only!! selby.plan Link to comment Share on other sites More sharing options...
winterdd Posted June 20, 2019 Author Share Posted June 20, 2019 heck yeah!!! thanks for educating me rene! 2 Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 20, 2019 Share Posted June 20, 2019 22 minutes ago, ChiefUserBigRob said: heck yeah!!! thanks for educating me rene! sure thing, got you an up-vote for your enthusiasm..haha, gotta get you back in the positive Link to comment Share on other sites More sharing options...
winterdd Posted June 20, 2019 Author Share Posted June 20, 2019 yeah, i kinda got aggravated here recently...oops! Link to comment Share on other sites More sharing options...
