Delete Dimension is Deleting CAD lines
postandbeam
10 minutes ago, postandbeam said:
Hello, I recently upgraded to X11 (newest update applied).  I drew some CAD lines and used the manual dimension tool for some line spacing.  When I delete the dimension line, it deletes the cad lines it is measuring.  Is this a new behavior (need to un-associate the dimensions to the CAD somehow?), or is it a bug?
Chief Talk Question.plan
Very strange behavior..I went ahead and fixed it:
Chief Talk Question (1).plan
1 hour ago, postandbeam said:
@Renerabbitt- Thanks for fixing it, is there any way you could explain what you did?  The file I uploaded was a "dumbed down" version of my drawing and would like to fix it in my core drawing.  Thanks!
for some reason your at-mention didnt ping me...anywho...I dropped a new cad lin in and then moved the dimension handles to the new cad line and deleted the dimension.
alternatively, you can group select my drawing and cad-block the selection, paste it in your plan and use the point to point move tool to position in your new plan..then delete the old.
Some really funky stuff going on there.
I got things to work a bit better by opening the polylines' dbx's and on the Arrow panel, unchecking Attach to Tail Of Other Objects and Attach to Head of Other Objects.
There are still some problems.
Turning off the display of arrows seems to help further.
Probably a good one to send into Chief.
Do you know what you did to get that result?
    30405
    ElzaBDesign
    ElzaBDesign
