Arrow keys acting wierd
AllenTinius
I am having an issue in X10 where when I select an object and use the arrow keys to adjust the position, the object does not move in the expected direction.  The down key moves the object to the left, the left key moves the object up, etc.    However, if an object is not selected, the arrow keys move around the plan on the screen in the correct direction.    Also, text is oriented rotated as if the left side of the screen is the front of the plan.     I have looked and cannot find the preference that I have set that is causing this.    Any suggestions would be appreciated.
