DRyeHD Posted June 12, 2019 Share Posted June 12, 2019 I am trying to use the "lower wall type if split by butting roof" without success. I have used this before and the correct view actually shows up in the Wall Specification View. But my cross sections and camera views all show exterior siding on the inside wall. When I try to pull the roof plane through the exterior wall material, it snaps back to the original position. I am attaching the plan file and would appreciate any input on what I'm doing wrong. Bond.zip Link to comment Share on other sites More sharing options...
DRyeHD Posted June 13, 2019 Author Share Posted June 13, 2019 Thanks for taking a look at this. I tried reversing the wall but must have still done something wrong. I had to change all exterior walls from brick to siding - must have missed something somewhere. I will delete the previous thread. Link to comment Share on other sites More sharing options...
DRyeHD Posted June 13, 2019 Author Share Posted June 13, 2019 Eric, Thanks so much for the video! I will be spending some time on going through your advice. Link to comment Share on other sites More sharing options...
Mark3D Posted June 13, 2019 Share Posted June 13, 2019 i had play with this problem and could not see what was wrong give it to tech support you they will spot it in quick i would think https://support.chiefarchitect.com/home Link to comment Share on other sites More sharing options...
DRyeHD Posted June 18, 2019 Author Share Posted June 18, 2019 Solver, I stepped through both videos you provided as I cleaned up roof openings and interior walls. Again, thanks so much! Link to comment Share on other sites More sharing options...
kMoquin Posted June 18, 2019 Share Posted June 18, 2019 Good videos Eric In the 2nd one- another option would be to use the header settings for the doorway instead of manually drawing the beam. Link to comment Share on other sites More sharing options...
