zowie123 Posted May 22, 2019 Share Posted May 22, 2019 Hi all, Anyone else notice a lot of crashing when dealing with cad details? I haven't had this many crashes in several years. Clean load, stock templates. Very few alterations. Thank you, Barry Link to comment Share on other sites More sharing options...
rlackore Posted May 22, 2019 Share Posted May 22, 2019 I've been getting more than the usual number of "unhandled exception" errors and freeze that force me to end the program process. The oddest thing that happens is I will lose the ability to select any object by clicking - I have to marquee select instead; the only method to re-trigger the click-select ability is to switch windows, open/close a view, or something similar. Link to comment Share on other sites More sharing options...
Dermot Posted May 23, 2019 Share Posted May 23, 2019 As far as I can tell, we have not received any reports of any problems similar to what you have described. If you can reliably reproduce these problems, then please report them directly to our technical support team. If we can reproduce them in house, then we will always try to get a fix into the next available update. On a side note, if you ever get an error message that says "unhandled exception", then you should treat the plan as if it is now corrupt. You should either exit the program without saving or do a "save as" to make sure you do not accidentally overwrite a good version of your plan. Link to comment Share on other sites More sharing options...
rlackore Posted May 23, 2019 Share Posted May 23, 2019 32 minutes ago, Dermot said: If you can reliably reproduce these problems, then please report them directly to our technical support team. Of course, but most of our time is spent working and not recording each mouse-click in anticipation of an error or crash. Link to comment Share on other sites More sharing options...
