DianeP Posted May 12, 2019 Share Posted May 12, 2019 I am setting up x10 and x11 in a new computer. Can't remember the setting to change to stop the old layout box from changing when a new one is sent...IE is sent the floor plan view and then the foundation view. Now I have 2 foundation views because the floorplan view changed to foundation view as well. Link to comment Share on other sites More sharing options...
DianeP Posted May 12, 2019 Author Share Posted May 12, 2019 figured it out check the box on make copy of active layerset. Seems like this should be default mode fore CA out of the box. Link to comment Share on other sites More sharing options...
parkwest Posted May 12, 2019 Share Posted May 12, 2019 Are you sure it's not your Saved Plan View that you want? Link to comment Share on other sites More sharing options...
Dermot Posted May 12, 2019 Share Posted May 12, 2019 Making a copy of your active layer set only makes sense if you know almost nothing about layer sets (or if you understand them completely and find it a convenient way to create a new one and always specify a more reasonable name). It also has the side affect of disabling the linking of layout boxes to saved plan views. I suspect that your real problem is that you are sending a saved plan view to the layout without realizing that the layout box will be linked to the saved plan view. Please check out my comments on this thread regarding saved plan views: Link to comment Share on other sites More sharing options...
DianeP Posted May 12, 2019 Author Share Posted May 12, 2019 On 5/12/2019 at 4:33 PM, parkwest said: Are you sure it's not your Saved Plan View that you want? Expand On 5/12/2019 at 4:47 PM, Dermot said: Making a copy of your active layer set only makes sense if you know almost nothing about layer sets (or if you understand them completely and find it a convenient way to create a new one and always specify a more reasonable name). It also has the side affect of disabling the linking of layout boxes to saved plan views. I suspect that your real problem is that you are sending a saved plan view to the layout without realizing that the layout box will be linked to the saved plan view. Please check out my comments on this thread regarding saved plan views: Expand you guys are right.... I have just been accustom to using the active layer set. I will give this way a try. Link to comment Share on other sites More sharing options...
