Roof Section Help!
jjifmeyer
I think you either need to reduce the roof height of the front porch. reduce it's width, or reduce it's pitch so that the ridge will clear the upper floor window.
I would also adjust the depth of the covered porch on the left so that the hip meets the upper floor corner - but that is being very pedantic.
Roof done automatically:
Still can't get this to work for me.
Not sure why I'm having so many problems.
I did lower the height of the window but cant get things to line up.
If I could duplicate "glennw's" work I would be good to go.
I can't get it to auto generate as "glennw" did.
I have uploaded a new plan.
Any help and an explanation would be much appreciated.
Thanks
Tony_House2.plan
That did not work.
In your original response above what did you lower the pitch of the 2 wall too?
1 hour ago, solver said:
Adjust the pitch on the marked walls and watch what happens.
I lowered then to 3"
Thanks
Thanks
Thanks for the help but it still does not work for me.
I give up
24 minutes ago, solver said:
2 on the side wall and 3-3/8 on the front.
Thanks
