SaeidA Posted May 2, 2019 Share Posted May 2, 2019 The line weight field has no effect when drawing a simple CAD line. It doesn't seem to matter what number I enter for line weight, they always appear to be the same thin line. I understand the number represents 100ths of inches or mm, but in either case, whatever number entered has no effect on the displayed line. Didn't see any bug reports, so I'm guessing I'm doing something wrong. Any ideas? I'm using Chief Architect Premier x10 on a windows laptop. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 2, 2019 Share Posted May 2, 2019 If you want to see the line weights on screen while you are working toggle on line weights or print preview. 1 1 Link to comment Share on other sites More sharing options...
HetrickDesign Posted May 3, 2019 Share Posted May 3, 2019 I'm having this issue too. I guess it's a bug? All lineweights are the same even in the wall type later dbx. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 3, 2019 Share Posted May 3, 2019 29 minutes ago, nVisionTEKBIM said: I'm having this issue too. I guess it's a bug? All lineweights are the same even in the wall type later dbx. Not seeing it in X10 or X11. Maybe you should compare video driver versions. If that is not it I have no idea where to go with that problem. Maybe try and toggle it in Preferences> Appearance> "Show Line Weights" if you want it on all the time. Link to comment Share on other sites More sharing options...
justmejerry Posted May 3, 2019 Share Posted May 3, 2019 Are they legacy plans or HD plans? Could cause the issue perhaps. There is another recent post about line weights that mentions this. Link to comment Share on other sites More sharing options...
HetrickDesign Posted May 3, 2019 Share Posted May 3, 2019 5 hours ago, justmejerry said: Are they legacy plans or HD plans? Could cause the issue perhaps. There is another recent post about line weights that mentions this. I'm currently working on a project that was created from a homeowner using HD. I will look for that post, thanks. Link to comment Share on other sites More sharing options...
HetrickDesign Posted May 6, 2019 Share Posted May 6, 2019 On 5/3/2019 at 1:55 AM, justmejerry said: Are they legacy plans or HD plans? Could cause the issue perhaps. There is another recent post about line weights that mentions this. Can you point me to this? I couldn't find the post. Link to comment Share on other sites More sharing options...
justmejerry Posted May 6, 2019 Share Posted May 6, 2019 Here you go Dustin. https://chieftalk.chiefarchitect.com/topic/22373-printed-lines-are-too-think/?tab=comments#comment-182485 Link to comment Share on other sites More sharing options...
SaeidA Posted May 7, 2019 Author Share Posted May 7, 2019 On 5/2/2019 at 3:56 PM, Chopsaw said: If you want to see the line weights on screen while you are working toggle on line weights or print preview. That was indeed the problem. I went all over the documentation, but couldn't readily find out about this toggle. I assume it's there somewhere. Thank you Chopsaw. 1 Link to comment Share on other sites More sharing options...
ldharris Posted 3 hours ago Share Posted 3 hours ago Hey, Great Inform!!! For some reason when I open any plan, all of my line weighs were gone. I still don't know how this option got turned off. But thanks for your help SaeidA! You just saved me many hours of frustration and work! Link to comment Share on other sites More sharing options...
