Brick edge on patio
Gary_Swanson
  • 7 months later...
I have been trying to solve the same issue...
Is there an article to walk me thru these steps needed? I have drawn a 2.5" thick, 6" wide, and 9" long paver brick to be used as a soldier course around the patio, but it keeps getting extruded to 24" long when its saved into my library. So I end up with a 2.5" thick, 6" wide, and 24" long brick.
Thanks for any help you can provide!
  • 4 weeks later...
The fix is to build a solid 3D molding and apply the "single course" brick material to it. From there you can adjust the scale and such as needed. But what I can't seem to do is get the brick to show without the grout between the bricks. Pavers are butt tight and the grout in the renderings throws off the feel of the patio some.
So turns out I have read that article. Its kind of like I want to do... but not exact. I think I will have to settle for the bricks showing the mortar. We do a lot of renderings as part of our project proposals and breaking down the permitter of the patios into line sections and placing objects along the line for each line (for each version of the plan we present) is a lot of time. In the spring we don't have a lot of time as we are running a massive amount of bids and sending many renderings.
