ray trace Grainy ray trace
Member Statistics
Similar Content
By Tkangas
I am very perplexed by the lack of light in the interior physically based ray tracing camera. They always appear to be taken with all the interior lights off.
What I have tried so far:
- adjusting the camera exposure and brightness
- adding lights and light sources
- increasing the maximum number of lights on
- adjusting the sun angle, etc.
I can NOT figure out how to make the interior rooms brighter!! I would LOVE if someone can help! This is a very powerful tool if it can be rendered correctly
both attached images have light sources that are turned on
By stevenyhof
Is there a way to set a default to turn Ray Trace off when selecting Physically Based. I tried to open the Camera in my template and select Physically Based and turn off Ray Trace and save, but it does not save.
By nannadajin
Hello!
I'm trying to render white high-gloss cabinets but unable to get the correct settings... can anyone advise?
I am using ray trace in Chief Architect. I tried using the mirror material but when I do that it renders as black. Thank you!
By pgjacob
HI All
I am ray tracing a scene with a 3D plant (from sketchup) and the shadows are showing squares rather than the actual shadow of the plant (1 pass image shown below). I have purposely moved the sun around to cast shadows to the back of the image as I have found manually manipulating the sun gives much better RTs than using natural sun angles (at least for me). I attach the skp file and what the plant looks like in the object info window of CA. Any ideas how to get rid of this square shadow? I uncheck the ray casted shadows in camera tool pre-ray trace, and it looks better but still ray traces with the square shadow.
Thanks in advance,
melissa
Blue Flax Lily.skp
By LeeDrafter
Hi All, I am trying to achieve a ray trace with a tree in the foreground that sort of frames the picture. Attached is an example of my goal- I did not create the attached jpg. I am getting close by placing a tree close to the camera but mostly out of view, but every tree I have tried is blurry. See the saved camera in the attached file. Then I place another big tree closer to the house to create a shadow on the house/driveway. I will crop that tree out of the final picture. Are there any trees CA has that you recommend for close-up high resolution (5500x3200 pixels) ray trace? I found a thread from the old Chief Talk where they had a similar problem and Larry Kumpost suggested a high res tree, but I don't know where to find one. Here is the old thread http://www.chieftalk.com/showthread.php?34289-Exterior-Critique&highlight=trees+foreground. Thank you in advance!
THE ADLER RENDERING.zip
