Slamnation Posted April 2, 2019 Share Posted April 2, 2019 Is it possible to change the Wall Board (Drywall) size from the default size of 4x8 to 4x12 when CA calculates the materials list? Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 2, 2019 Share Posted April 2, 2019 Yes but the method depends on which version of the software you're using. My models use three types of drywall: 4' x 12' 1/2", 54" x 12' 1/2", and 4' x 12' 5/8" Link to comment Share on other sites More sharing options...
Kbird1 Posted April 3, 2019 Share Posted April 3, 2019 1 hour ago, Slamnation said: Is it possible to change the Wall Board (Drywall) size from the default size of 4x8 to 4x12 when CA calculates the materials list? Change the Material defined in the Wall definition.... And do you Forum signature please.... ie many answers need the software version in use...... you may even be on the wrong forum if using a HD Title and not CA Premier. Link to comment Share on other sites More sharing options...
Slamnation Posted April 3, 2019 Author Share Posted April 3, 2019 Sorry. I'm Using CA X10. Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 3, 2019 Share Posted April 3, 2019 30 minutes ago, Slamnation said: Sorry. I'm Using CA X10. In X10, this change is done on the General panel of the Define Material specification. There you can change the Sheet size. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 3, 2019 Share Posted April 3, 2019 1 hour ago, Chrisb222 said: In X10, this change is done on the General panel of the Define Material specification. There you can change the Sheet size. Or use the Sheets already made in the Library too. Link to comment Share on other sites More sharing options...
