How to delete casing in sidelight windows?
1090291004350551
I have a problem with sidelight windows in very thick walls. I think it is obvious from the screenshot. Windows (and doors) have this think "wall" between themselves and central door. When I mull the objects these walls stay.
Is there a way to remove them?I deleted casing but it wouldn't help.
Expand
I hate to be captain obvious, but its probably because there is no such thing as a single framed wall that thick.   Eric's idea is probably a practical solution, but you also might just try modeling the condition out the actual way it would be built - the software works much using it that way.
