capitaldesigns Posted March 21, 2019 Share Posted March 21, 2019 Is there a way to change the line scaling ? I drawing a property line using the line with long line followed by 2 dashes followed by another long line. Looking at this line in the plan the lone line is very short and the dashes look like little dots. On one of the property lines that is 250' long there are over 100 of these line, 2 dashes, line combinations. So many that when printed you can not see any of the lashes. Is there away to spread these dashes out so there not so close together ? I tried using the line with the P/L imbedded in the line. Again there a hundreds of the P/L going around the property lines. I usually would only have one or two along each property line. Thanks, Mike Link to comment Share on other sites More sharing options...
tommy1 Posted March 21, 2019 Share Posted March 21, 2019 I would make a custom line style with the spacing you need. Will be a bit of trial and error until you get what you want. If you're going to send to layout at an engineering scale, you should probably check that too. 1 Link to comment Share on other sites More sharing options...
capitaldesigns Posted March 21, 2019 Author Share Posted March 21, 2019 I will try that. I come from an AutoCAD background. In AutoCAD you can change the spacing of these line by command called line type scaling. I did not know if CA had such a command. I see you upgraded to X11. How do you like it ? In your opinion is worth upgrading from X10 to X11 ? Thanks, Mike Link to comment Share on other sites More sharing options...
tommy1 Posted March 21, 2019 Share Posted March 21, 2019 28 minutes ago, capitaldesigns said: I see you upgraded to X11. How do you like it ? In your opinion is worth upgrading from X10 to X11 ? Yes I like it. Link to comment Share on other sites More sharing options...
Evolution Posted March 21, 2019 Share Posted March 21, 2019 Mike, I think you'll be pleasantly surprised by the X11 upgrade. Link to comment Share on other sites More sharing options...
