OnlineBuilder2 Posted March 21, 2019 Share Posted March 21, 2019 Im exporting my 3D models to Digital Locker but they are not opening. eg: https://accounts.chiefarchitect.com/3DV/view?share=102145342441523 Anyone know why this would be happening? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 21, 2019 Share Posted March 21, 2019 Likely your model is too large or too detailed. You can exceed the recommendations a little but there is a limit. https://www.chiefarchitect.com/support/article/KB-03068/viewing-managing-and-sharing-3d-viewer-models.html Link to comment Share on other sites More sharing options...
Kbird1 Posted March 21, 2019 Share Posted March 21, 2019 Likely a face or texture count issue as CS mentioned , try and optimise the File 1st..... https://www.chiefarchitect.com/support/article/KB-03044/optimizing-a-chief-architect-plan-for-export-to-the-3d-viewer.html Link to comment Share on other sites More sharing options...
Kbird1 Posted March 24, 2019 Share Posted March 24, 2019 What I hadn't noticed to till today was that at the bottom of the KB Tutorial I linked above there is an Attachment from Chief with 3 new 3D Viewer Layersets you can import into any Plan ( or your Template File) and switch too for different Views before exporting to the 3D Viewer, they are a good Starting point though you may lose terrain , plants etc especially at the Good setting. ie GOOD-BETTER-BEST Link to comment Share on other sites More sharing options...
Kbird1 Posted March 24, 2019 Share Posted March 24, 2019 On 3/21/2019 at 5:19 AM, OnlineBuilder2 said: Anyone know why this would be happening? Expand Although my current File doesn't exceed the Limits , I think the Standard View not loading is due to too many Trees in the Forest I "planted" behind the house for Views , as I get a out of memory error, so I may need to just go back to an Image of a Forest instead. M. Link to comment Share on other sites More sharing options...
