Lilidesignbuild Posted March 20, 2019 Share Posted March 20, 2019 Hello please see the attached picture of what I'm trying to draw. It's a tile roof with partially exposed decorative framing. I did a typ. roof then I drew the rafters and beams manually, but I can't seem to give them a pitch. Thanks! Link to comment Share on other sites More sharing options...
Lilidesignbuild Posted March 21, 2019 Author Share Posted March 21, 2019 Followed your suggestion, checked build framing and nothing appears. Do I need to click or check something else to make structure appear? Link to comment Share on other sites More sharing options...
tommy1 Posted March 21, 2019 Share Posted March 21, 2019 I had this same situation a few months ago (X10). I'll go back and see what I did. Probably not the best approach but got it done. Sorry, mine is different from yours. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 21, 2019 Share Posted March 21, 2019 8 hours ago, Lilidesignbuild said: Followed your suggestion, checked build framing and nothing appears. Do I need to click or check something else to make structure appear? Yes, if you are framing a ceiling plane as Eric suggests make sure your ceiling framing layer is turned on... Link to comment Share on other sites More sharing options...
