ELEVATION frustration----Furred wall will not show electrical when using the wall elevation tool! WHY?!
morganbass123
I can get the electrical to show up with backclip and or cross section but not by using the Wall elevation button! This is frustrating anyone have a fix for this? I'm new to using the furred wall as an option so maybe there is something I am unaware of. Thank you!
I have seen this issue reported before and there are threads on it so do a search as you haven't filled in your Signature so nobody know what version you are using.
*** to fill in your Signature .... go up to the top RH Corner above and click on your UserName> Account Settings> Signature.... and enable Signature (will Turn Green) then add your Hardware Details and Chief Software Version, as different Version require different Answers.
