LED Mirrors
K80Guy
As Mark said. Just applied a polyline solid to the mirror and set the emissive.
This one uses actual lights around the perimeter positioned behind the frosted glass edge. If you have X11 you could use the new rope light to accomplish this. (Edit: Rope light probably won't work as you can't draw it on the vertical).
  • 4 weeks later...
