Garage door header
builtright3
Are your walls framed?  The program will only build headers for openings in framed walls.
Did you build the wall framing?  The program will only show the framing that has actually been built.
Is your garage door setup to build a header?  You can control door framing for each door independently or through the door defaults.
These are just the most obvious things that I could think of.  There are lots of other possibilities.  If you posted the plan, I bet someone could tell you the problem in less than 5 minutes.
47 minutes ago, justmejerry said:
Check here Joe.
Thank for the help!
The problem was that it was an addition and I didn't build the wall framing on that part of the house yet. I just over looked it. These things happen more and more with old age! LOL
Sorry I took up your time with my imbecility!
