Simons Posted September 13, 2014 Share Posted September 13, 2014 Hi to all, I am designing a home with gourmet space that in this environment there is a grill indoors.I need a barbecue with chimney on the roof library. Only found one with very low chimney to external environment.Someone would have to send me, please. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 13, 2014 Share Posted September 13, 2014 Create a slab or poly-line solid to represent the flue extention and use an existing symbol for the grill. DJP Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 14, 2014 Share Posted September 14, 2014 also you ma be able to create a stretch zone with a copy of that symbol Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 14, 2014 Share Posted September 14, 2014 Just in case you don't know how to create such a stretch plane: 1. Select the Symbol and Open it (chair icon on the Edit Toolbar) 2. Click the "Size" Tab 3. Set the z Stretch Plane at just slightly less than the height of the Symbol. That will cause any resize or stretching to occur only at that height. Everything above or below that will be unchanged. 1 Link to comment Share on other sites More sharing options...
