SawyerCD Posted February 11, 2019 Share Posted February 11, 2019 Good Morning, I'm wondering if anyone knows of a way to add a dwg cad block to chief architect's library. I would like to import a cad block to my library and then use it to represent a 3d shower in plan view. Does anyone know how to do this? Thanks in advance for the help! Link to comment Share on other sites More sharing options...
tommy1 Posted February 11, 2019 Share Posted February 11, 2019 When you say "cad block", that implies it's already blocked. Select the cad block and on the edit tool bar at the bottom, you'll see where you can add it to the library. If it's not blocked, select it all and block it. then you can save it to the library from the edit tool bar at the bottom of your screen when selected. Link to comment Share on other sites More sharing options...
joey_martin Posted February 12, 2019 Share Posted February 12, 2019 Drag and drop. Blocks can be imported as well from the edit menu, but ordinarily I simply grab what I want and drag and drop. Link to comment Share on other sites More sharing options...
