CalebDBCH Posted February 1, 2019 Share Posted February 1, 2019 Hi All, as you see in the attached pic, I want to shrink the Board and Batten in this gable, and extend the lap siding up. What is the proper way to do this? Thanks! Link to comment Share on other sites More sharing options...
chief58 Posted February 1, 2019 Share Posted February 1, 2019 try a cross section camera select the wall and drag it up to where you want it to be Link to comment Share on other sites More sharing options...
CalebDBCH Posted February 5, 2019 Author Share Posted February 5, 2019 Sorry for the delay, I have been traveling and have not had cell signal or wifi.... Yes, the goal is to have the framing accurate. Link to comment Share on other sites More sharing options...
javatom Posted February 5, 2019 Share Posted February 5, 2019 For accurate framing, you would want to go with using a material region. 1 Link to comment Share on other sites More sharing options...
parkwest Posted February 5, 2019 Share Posted February 5, 2019 If accurate framing is important... then Eric (solver) gave you the answer. IMHO, I would go with the wall material region for quick and easy. 1 Link to comment Share on other sites More sharing options...
