EconBlueprints Posted January 28, 2019 Share Posted January 28, 2019 I need to change the floors and ceilings on a two story building from 9-1/4" 2x10 floor joists with 3/4" sub-floor to 11-7/8" LVL floor joists with 3/4" sub-floor. This needs to be done on both the first and second floors Also, the ceiling heights need to go from 97 1/8" to 109 1/8" (rough framing) on both floors. First, I changed the framing in the build framing dialog box. That seems to have done what I want, I now have 11-7/8" I Joists for both floors. I can do the floor/ceiling height change by clicking on each room on each floor and making the change in the structure dialog box. Is there a quick method to select all the rooms on each floor and then do a single ceiling height/floor height that would apply to all rooms on that floor? Link to comment Share on other sites More sharing options...
MoeGia Posted January 28, 2019 Share Posted January 28, 2019 There are a few ways but the easiest (and best practice) way is by modifying the floor defaults. There's an icon or you can access Floor Defaults through the main Defaults dropdown. Sorry, I don't have Chief on this device or I'd include a screen shot. Modify the floor system here too. After you modify the floor defaults, go back to your plan and be sure each room is set to 'Use Defaults'. Select One room, tick the boxes, then use select same to view/apply to all the other rooms. 1 Link to comment Share on other sites More sharing options...
EconBlueprints Posted January 28, 2019 Author Share Posted January 28, 2019 Thanks! Link to comment Share on other sites More sharing options...
rlackore Posted January 28, 2019 Share Posted January 28, 2019 22 minutes ago, solver said: See Edit>Reset To Defaults Thanks for that nugget Eric - something I've missed and it will certainly be useful for me going forward. Link to comment Share on other sites More sharing options...
