JimSoholt Posted January 6, 2019 Share Posted January 6, 2019 I'D LIKE TO KNOW HOW TO PRINT A HARD COPY OF THE LAYER DISPLAY OPTIONS of A SPECIFIC LAYER SET IN A SPECIFIC PLAN, SO I CAN COMPARE IT WITH THE DISPLAY OPTIONS OF A DIFFERENT LAYER SET. JIM SOHOLT CAMPBELL, CA Link to comment Share on other sites More sharing options...
glennw Posted January 6, 2019 Share Posted January 6, 2019 As per your other post. You could open a second instance of Chief to compare. or..do a screen capture and view or print Link to comment Share on other sites More sharing options...
Kbird1 Posted January 6, 2019 Share Posted January 6, 2019 Printing a Screen capture would be the easiest way..... M. Link to comment Share on other sites More sharing options...
JimSoholt Posted January 6, 2019 Author Share Posted January 6, 2019 GLENNW, THANKS. OPENING A SECOND INSTANCE of CHIEF SOUNDS EXCELLENT. . . . BUT WHEN I TRY THAT I GET A MESSAGE TO THE EFFECT "CHIEF IS ALREADY OPEN. OPENING ANOTHER INSTANCE OF IT IS NOT RECOMMENDED." IS THERE A GOOD, SAFE WAY TO OPEN AND RUN TWO INSTANCES OF THE PROGRAM SIMULTANEOUSLY? JIM SOHOLT CAMPBELL,CA USA (I HOPE I'M REPLYING TO YOUR RELY IN THE CORRECT WAY. I'M A NEW (UNSURE) USER HERE at FORUM) Link to comment Share on other sites More sharing options...
Kbird1 Posted January 6, 2019 Share Posted January 6, 2019 3 minutes ago, JimSoholt said: GLENNW, THANKS. OPENING A SECOND INSTANCE of CHIEF SOUNDS EXCELLENT. . . . BUT WHEN I TRY THAT I GET A MESSAGE TO THE EFFECT "CHIEF IS ALREADY OPEN. OPENING ANOTHER INSTANCE OF IT IS NOT RECOMMENDED." IS THERE A GOOD, SAFE WAY TO OPEN AND RUN TWO INSTANCES OF THE PROGRAM SIMULTANEOUSLY? JIM SOHOLT CAMPBELL,CA USA (I HOPE I'M REPLYING TO YOUR RELY IN THE CORRECT WAY. I'M A NEW (UNSURE) USER HERE at FORUM) You don't need to use all CAPS Jim ...in internet speak that is the same as "shouting"..... Hold the Ctrl Key as mentioned on your other Thread to open two instances at once.... M. Link to comment Share on other sites More sharing options...
