Skylight-Window schedule
ShaneK
Here are the ones I have found on the Forum and altered a bit to play with in the past Shane..... , put the Skylight on the Roof and it's corresponding Skylight as Window into a short Wall off to the side.... you need to cut your own Roof holes with the Skylight symbol if needed for 3D views just remember that the Hole should be shorter than the Skylight top to bottom ( due to roof slope) and to make the Frame 1/16" tall and wide, the Symbol can sit on top of that hole then, the hole will also do the Framing.
All Credit to JoeCarrick for this method.
Skylights for Window Schedule Use_MHD.calibz
