Renerabbitt Posted January 3, 2019 Share Posted January 3, 2019 This has been brought up a few times and I just had a face-slapping moment...of-course there is a very easy way of doing this! Simply place a curved railing on top of your staircase. Go to the staircase dbx and at the "rail style" tab, scroll down to "build from" and check the box marked "Follow Stairs." Next, on the same tab under "Specify Railing" check "Panels." A very simple wainscot panel can be created by placing the "raised panel doors" cabinet door symbol into a plan and pulling a 3d view. In 3d go to the "Tools" menu and scroll down to the "Symbol" drop-down menu and select "create a symbol" Select the drop down menu and select "millwork" for your new symbol. This will add it to the user library as millwork, which can then be applied to your curved railing as a wainscotting. Go to the railing dbx and scroll to the "Newels/Balusters" tab and under "Panels" select from Library and find the millwork you just created. Make sure to set your newel spacing to something like 16" and your newel size to 0" Here is a simple result which took 5 minutes to create: plan file for reference: stair example.plan Thanks to @TheKitchenAbode for sparking the idea 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 3, 2019 Author Share Posted January 3, 2019 @Richard_Morrison For you! hope this helps Also @Alaskan_Son and @Kbird1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 3, 2019 Share Posted January 3, 2019 29 minutes ago, Renerabbitt said: @Richard_Morrison For you! hope this helps Also @Alaskan_Son and @Kbird1 It doesn't count if you don't post the plan we all know your skills with 3D imagery Thanks for pinging me.... Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 3, 2019 Author Share Posted January 3, 2019 8 minutes ago, Kbird1 said: It doesn't count if you don't post the plan we all know your skills with 3D imagery Thanks for pinging me.... HAHA, nice, posted here and in original post as en edit: stair example.plan The end user will probably get missing texture warnings, I never use stock stuff Link to comment Share on other sites More sharing options...
