ChiefuserMathews
Auto Interior Dimension
Because you are missing a room definition?
    27636
    Treasuretree
    Treasuretree
  • Similar Content
    • By MichaelaS
      I have a railing that is currently being dimensioned to from the outside of the panel. I would like to transition that dimension to either the center of the post or the outside of the post. However, I am unable to manipulate the extension line itself to snap to the corner of the post.
    • By PrimeArch
      Hello guys
      I have a problem with area calculation area.
      The room actual size is 3m x 3m ( 9 m2 )
      The wall must be center line. The problem is CA calculate outer side of the room. ( 9.92 m2 )
      How do i get a calculation by center line. ( 9 m2 )
    • By islandog
      When having multiple walls joining each other is the a way to align the distance off one room corner to another by dimension instead of dragging which is more difficult and time consuming and not as presise . I tried to alter offset of each room by clicking a wall and changing the dimension and it resizes the room
      Thx
    • By Lorenchief
      I'm trying to figure out why I can sometimes click on a dimension on screen and type in the new dimension and other times not find where to click. Am I missing something? I can't find any clear answer in the user guides. Trying to pull a line can be really tedious while simply typing in a number is a sure thing.
    • By gelbuilding
      Cannot dimension in section elevation views.
      The cursor goes weird on the elevation view trying to drag a dimension.
