crosscutter55 Posted November 28, 2018 Share Posted November 28, 2018 I want to create a 8" x 24" tile for a border on a bathroom floor . I have managed to get the sizing correct , however when i find the tile in the dale tile library i can not get the grout lines adjusted so it is a solid 8" x 24" tile . I have tried the material definition tool . Can someone please walk me through the settings for this :( Link to comment Share on other sites More sharing options...
MarkMc Posted November 28, 2018 Share Posted November 28, 2018 1 hour ago, crosscutter55 said: I want to create a 8" x 24" tile for a border on a bathroom floor . I have managed to get the sizing correct , however when i find the tile in the dale tile library i can not get the grout lines adjusted so it is a solid 8" x 24" tile . I have tried the material definition tool . Can someone please walk me through the settings for this Textures use an image file, in the case of tiles the grout lines are part of the image so they can't be removed. If you alter the size of the texture ALL of it will resize so grout lines will change in proportion. Borders also present the issue of texture direction which is set based on Cartesian coordinates of the plan-you would need the border texture to change direction on two sides. The best ways I've found to deal with borders are either using polyline solids (often converted to a symbol) or material regions. Then us multiple copy or transform replicate. Attached is a plan with both-floor done with material region and borders done with multiple material regions that were copied to be 1/32 apart (change number style to decimal when doing that). The floor is set to be just a tad thinner than the border. The other is made of symbols that were created from psolids blocked together (happens to be one I'm working on for someone now) I eventually converted that one to a single symbol to place on a wall, Borders.plan Link to comment Share on other sites More sharing options...
rlackore Posted November 28, 2018 Share Posted November 28, 2018 Have you tried using the Define Material>Texture>Scale settings? I created this tile border using Material Regions assigned a copy of the floor tile Material with adjusted Scale and Offset values: Link to comment Share on other sites More sharing options...
