Balcony floor close in , fascia issue, fireplace chimney
Designer100
First one - the balcony fascia.
You have the balcony railing wall defined as a Fir Stud wall which really only gives you framing.
The front of the balcony gets it's information from the wall.
So, change the material in the balcony rail wall definition.
The roofs are a mess which i haven't got time to troubleshoot and work out how you did everything.
I noticed that baselines were in the wrong location, etc.
Why not auto build the roofs?
