Designer100 Posted November 6, 2018 Share Posted November 6, 2018 This home needs on front garage Gable 3:12 pitch lower and 8:12 pitch higer (48 inches in from plate) I can not get it to work with 2 pitches. Would appreciate help. Thanks newell.cheatheam@gmail.com Burris.Phillip_Plan_11.06,18.zip Link to comment Share on other sites More sharing options...
rlackore Posted November 6, 2018 Share Posted November 6, 2018 Draw one of the 3:12 sections. Then draw an 8:12 section by snapping along the inside edge of the 3:12 section. Then mirror/replicate. Link to comment Share on other sites More sharing options...
glennw Posted November 6, 2018 Share Posted November 6, 2018 Do you want to auto build roofs for the whole house? If so, you need to turn on auto build roofs and then set up the roof directives for all the external walls. In the case of the garage roof, make the front wall a Full Gable (no second pitch because that will result in a gambrel roof). You have the correct settings for the side walls of the garage. If you want to do it manually, do as Robert said above. I, personally would go for auto roofs because if you edit the plan, the roof will auto update - just my personal preference though. Link to comment Share on other sites More sharing options...
