EconBlueprints Posted October 26, 2018 Share Posted October 26, 2018 How do you taper a fireplace chimney? Fireplace is set at 6' Wide, firebox set at 36" wide, and height so it penetrates the roof and maintains the 24" above the roof at 10' offset. But I dont want it to be 6' wide all the way to the top. Starting about 2' above the firebox I want to narrow it down to 24" x 24" . Can I do that in the fireplace settings somewhere? I can keep the fireplace itself say 6' tall, then add a polyline solid above it to the dimensions I want and change the material to the same stone on the fireplace, but is there an easier, better way? Thanks, Lane Link to comment Share on other sites More sharing options...
lbuttery Posted October 26, 2018 Share Posted October 26, 2018 is there an easier, better way? Lane: there should be there should be a Fireplace and Chimney tool set for creating "standard" chimney and fireplace configs this should have been added to CA long ago but alas ... Lew Link to comment Share on other sites More sharing options...
EconBlueprints Posted October 26, 2018 Author Share Posted October 26, 2018 Thanks, I suspected as much Lane Link to comment Share on other sites More sharing options...
NRST8TRKR Posted October 26, 2018 Share Posted October 26, 2018 Lane, Stop the CA chimney at the height you wat to start the taper the finish with a solid the you cn change to the shape you want. Have a great weekend,Ken Link to comment Share on other sites More sharing options...
