ACADuser Posted October 26, 2018 Share Posted October 26, 2018 My wall mount fixtures are set to 72" & some 68". I changed the default setting (see picture) to 80" but doe not seem to change the light added from the library. Most are set to 72" or less for interior & exterior wall mounted lights. How can I change all (default to) 80"? Link to comment Share on other sites More sharing options...
Kbird1 Posted October 26, 2018 Share Posted October 26, 2018 That Default setting would only change the Fixture set as the Default Wall Fixture I believe..... The Default Fixtures are the ones in the Quick Electrical Dropdown only... The Library lights would need to be copied to your User Library and then the height can be Changed , and you wouldn't use the CA Library Core Item anymore as it is locked.(no changes) M. Link to comment Share on other sites More sharing options...
ACADuser Posted October 26, 2018 Author Share Posted October 26, 2018 So is 72" deemed the standard for wall mount interior fixture heights? That seems too low to me. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 26, 2018 Share Posted October 26, 2018 22 minutes ago, ACADuser said: So is 72" deemed the standard for wall mount interior fixture heights? That seems too low to me. Depends on the type of Fixture Usually , ie is it concentric to the Box or hang down or point Up , so I usually use 78-84" depending on that and the Room Type etc, 72" must be a very old STD I think. Link to comment Share on other sites More sharing options...
ACADuser Posted October 26, 2018 Author Share Posted October 26, 2018 VERY OLD. Back when people were shorter & 30" vanities were being used. About time the database was updated I think. Thanks Link to comment Share on other sites More sharing options...
