jennyallan1 Posted October 21, 2018 Share Posted October 21, 2018 Hiya can anyone help or know if you can use your own backdrop photo on a walk through as when I drop mine in once I start the avi record it automatically sets a blue sky default backdrop. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 21, 2018 Share Posted October 21, 2018 If you are using X10 you will need to set a backdrop in Default Settings for your Full Camera which the walk through recorder uses. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 21, 2018 Share Posted October 21, 2018 if you use the x264vfw codec you will also get much smaller movie files that .avi too https://chieftalk.chiefarchitect.com/topic/17455-x10-windows-7-video-card/?do=findComment&comment=146648 Link to comment Share on other sites More sharing options...
jennyallan1 Posted October 21, 2018 Author Share Posted October 21, 2018 8 minutes ago, Chopsaw said: If you are using X10 you will need to set a backdrop in Default Settings for your Full Camera which the walk through recorder uses. OMG thanks so much I looked at but wasnt sure when I was in it what one to go under. 8 minutes ago, Chopsaw said: If you are using X10 you will need to set a backdrop in Default Settings for your Full Camera which the walk through recorder uses. 6 minutes ago, Kbird1 said: if you use the x264vfw codec you will also get much smaller movie files that .avi too Thanks so much I will download it Link to comment Share on other sites More sharing options...
