Jay_on_Cape Posted October 21, 2018 Share Posted October 21, 2018 Anyone else have the privilege of experiencing the old "truncating text" phenomenon in X10? I'm using X10 with the Chief Blueprint font. I lucked out and it went away for a few versions but it's baccckkkkkkkkkkkkkk...................... Link to comment Share on other sites More sharing options...
Kbird1 Posted October 21, 2018 Share Posted October 21, 2018 It happens quite often in Plans brought Forward .......the Fix is usually to Group Select all text , open the DBX, make no changes and close it again , so it fixes itself. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted October 21, 2018 Share Posted October 21, 2018 The problem is independent of the font. Happens with Arial, too. I have sent a number of plans in to Support, but they can never find anything, and they seem to have given up on trying to fix it. This is the only software program I have that has ever exhibited this behavior. As Mick says, it's easy to fix -- unless you miss it. And then it just makes you look bad. Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted October 22, 2018 Author Share Posted October 22, 2018 On 10/21/2018 at 7:24 PM, Richard_Morrison said: The problem is independent of the font. Happens with Arial, too. I have sent a number of plans in to Support, but they can never find anything, and they seem to have given up on trying to fix it. This is the only software program I have that has ever exhibited this behavior. As Mick says, it's easy to fix -- unless you miss it. And then it just makes you look bad. Expand What especially annoys me about this is the following..........You get a plan the way you want it. Hit save then close plan. It should open in the same state it was closed in. Open it up and your text is 1/2 gone......... BTW this plan wasn't brought forward but the profile plan was from X8 and completely blank with no text so it's any profile / or plan brought forward this could happen to. I don't need help looking amateurish.....I can do that quite well by myself.... Link to comment Share on other sites More sharing options...
SabGroup Posted October 23, 2018 Share Posted October 23, 2018 Nothing like sending out a 5 figure plan to the clients and their business partners and there is crap on the plan like ELEVATO AND KITCHENETT R E There are way to many moving parts in a project to have to worry about double checking text. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted December 4, 2018 Share Posted December 4, 2018 Any of you guys using hi DPI scaling or overall display scaling in Windows? I just discovered that resetting scaling to 100% from where it was set at 125% for my 4K monitor fixed the issue. Not happy with this solution, but may help tech support track things down. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2018 Share Posted December 5, 2018 On 12/4/2018 at 9:31 PM, Richard_Morrison said: Any of you guys using hi DPI scaling or overall display scaling in Windows? I just discovered that resetting scaling to 100% from where it was set at 125% for my 4K monitor fixed the issue. Not happy with this solution, but may help tech support track things down. Expand I also use 125% Windows Scaling (recommend) and sometimes also see this Issue. Link to comment Share on other sites More sharing options...
