EconBlueprints Posted October 18, 2018 Share Posted October 18, 2018 Hello again, My electrical schedule looks great....for the most part What I would like to do is have the devices on the exterior side of the building assigned to a room definition such as "Exterior". The kitchen ones show up as Kitchen, Bedrooms in the bedrooms, bathrooms in the bathrooms, but there are blank lines that look like they are just waiting to be filled in for any light, switch, receptacle etc. that is attached to the exterior of the building. I tried creating a room around each one of them, then giving it the room name of, for instance "garage exterior light", then making the room no locate, and the walls invisible, but that just made it worse in 3d views so I abandoned that idea. So, is there any way to assign the room name "Exterior Wall" or the like to those outside fixtures. I know I can put that in the comment line, but that is not what I want to do Thanks Lane Link to comment Share on other sites More sharing options...
rlackore Posted October 18, 2018 Share Posted October 18, 2018 I believe you're out of luck - Chief doesn't allow us to assign a name to the "Exterior" room. May i suggest creating a Custom Object Field and including it in the Electrical Schedule? I frequently use this strategy for other schedule types. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 18, 2018 Share Posted October 18, 2018 Robert, Nice solution. I use a lot of custom OIP fields but I hadn't thought of that one. Link to comment Share on other sites More sharing options...
rlackore Posted October 18, 2018 Share Posted October 18, 2018 If having the extra column is a nuisance, you could create a Custom Object Field that uses the %room.name% attribute. All the interior symbols would give you the Room Name, and for the exterior outlets you replace the %room.name% attribute with the exterior location. There are lots of possibilities. Maybe a Ruby macro could automate it even more. 1 Link to comment Share on other sites More sharing options...
EconBlueprints Posted October 18, 2018 Author Share Posted October 18, 2018 Perfect! Thanks so much Link to comment Share on other sites More sharing options...
