karenmbruns Posted October 4, 2018 Share Posted October 4, 2018 How do I get rid of halos/glare that is appearing at crown molding, around door ways, cabinets, etc. in ray trace view? Do I need to change the default for interior ambient light? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted October 4, 2018 Share Posted October 4, 2018 Place a roof on your structure, it's what we call light bleed. You can also reduce the sun intensity but best to use a roof. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 4, 2018 Share Posted October 4, 2018 Yep Bleed...., always build a Roof (or second story) and a Foundation even if you Model doesn't need one , CA uses them to "bounce" the light around in Raytrace and PBR views to some extent. I have also seen issues with Wall Definitions causing this in some plans posted here..... eg using interior walls for exterior walls M. Link to comment Share on other sites More sharing options...
karenmbruns Posted October 5, 2018 Author Share Posted October 5, 2018 So I put the roof on a complicated plan using auto build roof. After I edited the roof I had the X's from the roof intersections and I can't get rid of them. What do I do? Link to comment Share on other sites More sharing options...
Kbird1 Posted October 5, 2018 Share Posted October 5, 2018 4 hours ago, karenmbruns said: So I put the roof on a complicated plan using auto build roof. After I edited the roof I had the X's from the roof intersections and I can't get rid of them. What do I do? If you don't want them to show up at all? .......... disable them in Preferences...... see pic. Don't forget to do your Signature Please.... the Software Version in particular makes a difference on many answers, ie X7 is very different than X10. M. Link to comment Share on other sites More sharing options...
