Wainscot issue
andymcg
Good morning,
I was hoping someone had a solution on how to remove a wainscot from just one wall? Right now, I have the wainscot in as a Wallcovering so it's wrapping around the face of the shower. If there's a better way to do this I'm open to suggestions. Image attached.
Thanks!
Thank you so much! I also have another dumb question that I'm sure has a simple fix:
How do I set a layer to be the current default? For instance, when I'm doing an Electrical plan, I want the dimensions or any text to automatically come out on my Electrical layer, rather than having them come in on the default and me having to remember to go around and change each one.
I'm sure this is super basic, but I've never seen it covered in any of the tutorials and it's a CONSTANT pain to me.
Read about Annotation Sets. Chief comes with a default Electrical annotation set that you may use or modify as you wish.
Switch to it and text, for example, will be on the Text, Electrical layer.
Changing to the Electrical annotations will also change to the Electrical layer set.
Use Wall Material Regions for a more realistic Tile Installation , you can set thickness etc so I think it looks better , it's also fairly easy to do feature Bands this way too.
Set the tile so it doesn't cut the parent surface/object...ie it sits on the drywall/backerboard as in real life.
    30215
    Kaminski31
    Kaminski31
