Dimension
Onroad80
I am drawing a plot plan and the terrain perimeter is angled a few degrees.  How can I show a dimension between the terrain perimeter and the setback line?  The manual dimension tool doesn't work unless the terrain CAD lines are the set angles allowed by CA.  I turn off the angle snaps and grid snaps, and it still won't draw a dimension.
You can use the End-to-End Dimension tool, and if you have Preferences>Edit>Snap Properties>Object Snaps>On Object checked, the tool should infer the perpendicular as you drag the dimension to the second line. This screenshot was while the tool was active, with the cursor hovering over the second line as I was placing the dimension; note the green On Object indicator is visible and a blue dotted line shows the inferred perpendicular:
    30084
    TonyDW
    TonyDW
  • Similar Content
    • By McCallOfTheWild
      Hello everyone
      New to the Chief forum. I'll get right to it... I recently got magic plan for an iPad I have to easily do a floor plan when on site (Have always used pencil and 11x17 paper). It has it's ups and downs, but for the need to know dimensions (I shoot with laser, and it auto populates) it's been great and has cut my sketching time in half.
      I have learned that Magic Plan can export DXF files. I have been watching tutorials on YouTube, and have learned how to import DWF/DXF into Chief. Learned about layering and so forth.
      Here's the problem. When I import to chief and get all my ducks in a row, and layer all I can, chief won't recognize the cad windows when I go into perspective view. chief thinks they're all door openings in the wall when I Cad To Walls. How do I fix this? Using Chief x10.
      Thanks in advance.
    • By Ange822
      Good morning,
      I am helping a college who is having issues exporting a Chief File into a CAD . dwg file.
      The issue is, she had imported a .jpeg of a clients survey to draw over to create a site plan.
      Now trying to export the file to CAD, it will not export the .jpeg with it (that we sized / rotated into place).
      The other option would be just to import the .jpeg into CAD and re-size / rotate to fit, but wasn't sure if their was an easier way.
      See the files attached.
      thanks in advance for the help!
      McMillan -custom-VER.4- SITE - 08.17.21 ENTIRE LOT.plan McMillan -custom-VER.4- SITE - 08.17.21 ENTIRE LOT.dwg
    • By ChiefAR-MARGARET
      Can someone tell me step-by-step how to download the CAD details from the last free live webinar into my project browser?
      I found the file, extracted it, but I wasn't sure which folder to extract it into. So I tried several to no avail. Thank you!
    • By briang372003
      North Texas Design Solutions is a leader in providing custom residential home plans, offering a wide variety of designs that are construction-ready and that cater to a vast array of differing styles. Any of our in-house plans can be modified to meet your needs, or a new custom plan can be created from scratch. Our professional knowledge and experience, paired with your passion and specific needs, enables us to provide you with a home design that will leave you completely satisfied. This is why we say. “Where your ideas become your dream home”
      Some of the services we provide:
      3D Rendering, Architectural Design, Architectural Drawings, Barn Design & Construction, Building Design, Custom Homes, Drafting, Floor Plans, Guesthouse Design & Construction, Handicap-Accessible Design, Home Additions, Home Extensions, Home Remodeling, House Plans, New Home Construction, Pool House Design & Construction, Project Management, Site Planning, Tiny House Construction
    • By Quickchevys
      So I learned this software(somewhat) and designed a house for my family about 6 years ago and the plan is now in motion to build the house. I have since forgot how to do all of the editing of the house and need a few tweaks done as well as the roof properly done since I never was able to understand how to get that part right. I also know that some walls, floors, and stairs were kind of just manipulated to be close enough to look ok in the camera view. So I would like someone that has more experience with the program to kind of go through my drawings and correct the things that need to be corrected and also get files for blueprints ready. I never could figure out that part either.
