Area of a roof plane
capitaldesigns
55 minutes ago, capitaldesigns said:
Is there a quick way to find out what the sq. ftg. of a roof plane is ?
Thanks,
Mike
You can use the Roof Plane Label instead of the Arrow and pitch by specifying the Label and inserting an Object Specific Macro..... (Red Arrow)
or
You can also use a simple Macro in a Text Box with Leader Line (arrow) connected to the Roof Plane .....
make a macro in TMM (text below), and then insert it into the Text box via the Text box DBX
Roof Plane SqFt
%surface_area%
eg :
You can find other simple Macro's simply by connecting a Text Box with Leader to most Objects and inserting the premade macro     %objectproperties%     which will fill the text box with all the premade Macros CA understands automatically , you can then use them to get the info needed, in this case all the info that the Polyline Info Tab shows.
