Box window artifacts
DavidJPotter
Thanks Glenn, I will try that (that makes the box window the "wrong" depth but I will take it if it works.
Hey, you are of course correct, my point is that improper depth is improper function and should be repaired if possible by Chief Inc. Thanks again, Glenn!
David,
I agree it needs a fix, I was just trying to get you out of trouble.
I will have a play and see if I can figure out why it happens.
I think the same situation came up way back with one of Scott's plans and there was a different solution.
