ChiefUser8377 Posted July 31, 2018 Share Posted July 31, 2018 HDA 2018 Build 19.3.0.490.SX May 9, 2017 Hello I am well into my design and noticed two errors that I can't seem to resolve. These errors appeared within the last week, but I do not know why. First, when viewing my plan using the floor camera, the floor disappears and terrain appears. Second, when viewing using perspective full overview and zooming into the design, the floor is visible (concrete slab w/footings), but somehow walls have generated in the attic. As far as the mystery attic walls go, I am able to delete them, but some sort of base framework remains that I can not delete. I have duplicated the plan and systematically deleted everything thinking I must have added/altered something that caused this to happen, but all I am left with is a shell with no floor on full perspective overview and phantom walls (?) in the attic. I have attached the shell. Any help/advice would be appreciated. Take care. Fred Plan E.plan Link to comment Share on other sites More sharing options...
rlackore Posted July 31, 2018 Share Posted July 31, 2018 1 hour ago, ChiefUser8377 said: First, when viewing my plan using the floor camera, the floor disappears and terrain appears. This is because the Structure is defined with Floor Supplied by the Foundation Room Below. It's a Floor Camera - it won't display things that are on the foundation level. Link to comment Share on other sites More sharing options...
rlackore Posted July 31, 2018 Share Posted July 31, 2018 1 hour ago, ChiefUser8377 said: Second, when viewing using perspective full overview and zooming into the design, the floor is visible (concrete slab w/footings), but somehow walls have generated in the attic. I assume you're referring to these attic walls: Just delete them and they're gone. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 31, 2018 Share Posted July 31, 2018 6 hours ago, ChiefUser8377 said: First, when viewing my plan using the floor camera, the floor disappears and terrain appears. possibly this setting if you have it in HDA 2018? Link to comment Share on other sites More sharing options...
rlackore Posted August 1, 2018 Share Posted August 1, 2018 15 hours ago, Kbird1 said: possibly this setting if you have it in HDA 2018? Good tip. Perspective Floor Overview cameras have that setting, though Floor Cameras do not. Maybe your tip will give the OP a good alternative to using a Floor Camera. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 1, 2018 Share Posted August 1, 2018 1 hour ago, rlackore said: Good tip. Perspective Floor Overview cameras have that setting, though Floor Cameras do not. Maybe your tip will give the OP a good alternative to using a Floor Camera. True , I wasn't sure from the Post whether he meant a Floor Camera or a Perspective floor Camera as he mentioned Perspective Full Camera as well..... Link to comment Share on other sites More sharing options...
