GMBKitchens Posted July 18, 2018 Share Posted July 18, 2018 While using the "point to point" dimension tool, what am I doing wrong that my dimensions seem not in like with cabinet edges? Usually I have to do it about 4-7 times to do it where it looks right. Very frustrating. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 18, 2018 Share Posted July 18, 2018 Point to point creates its own dimension points relative to where you left click and release the mouse. I never use those for cabinet elevations. What I do you is the "end to end" dimension tool for cabinet elevations. Check it out and see for yourself. DJP 1 Link to comment Share on other sites More sharing options...
GMBKitchens Posted July 19, 2018 Author Share Posted July 19, 2018 Thank you very much David. I have a lot to learn still. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 19, 2018 Share Posted July 19, 2018 3 hours ago, GMBKitchens said: While using the "point to point" dimension tool, what am I doing wrong that my dimensions seem not in like with cabinet edges? Usually I have to do it about 4-7 times to do it where it looks right. Very frustrating. You may find that the Point to Point Tool is "snapping" to the GRID rather than where you are left clicking exactly , you can disable the GRID temporarily if needed , you will find that the Tape Tool is also effected by this if GRID Snapping is on. M. Link to comment Share on other sites More sharing options...
