KSRFTIPE Posted July 14, 2018 Share Posted July 14, 2018 My "Select Material" function has stopped working. No longer able to set material defaults of any kind. I can use "eye dropper" to change materials in 3-D view so there is a workaround. However changing material defaults is much better. This has always worked in the past. I am uncertain when it quick working. When I open the material window it shows the current default. When I click on "Select Material" it hangs up and no other input is accepted. Only way out is to hit ESC. Any ideas? Ken Chief Architect X3-X9 Windows 10 Desktop PC 64 bit Core I7 CPU @ 3.0 GHZ 32 G Ram NVIDA GeForce 980 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 14, 2018 Share Posted July 14, 2018 Try to update your video card driver. Link to comment Share on other sites More sharing options...
KSRFTIPE Posted July 14, 2018 Author Share Posted July 14, 2018 I saw that in the forum. My GeForce experience shows I have the latest. Link to comment Share on other sites More sharing options...
Mark3D Posted July 14, 2018 Share Posted July 14, 2018 I might be on the wrong track here but if you have spray painted a new material on a object and change it defaults it won’t change until you tell it to use it’s default material 1 Link to comment Share on other sites More sharing options...
KSRFTIPE Posted July 18, 2018 Author Share Posted July 18, 2018 Appreciate the responses. I figured it out. I am running a 4K screen when I moved my CA window over to the standard high res screen the material selector began to work. My theory is that it was video card related and had to do with its ability to run the high-res 4K screen. Solved. Link to comment Share on other sites More sharing options...
