DaliaSassoon Posted July 6, 2018 Share Posted July 6, 2018 Hi, I want to make concrete terrain stairs on a sloped terrain, and I have managed to figure that out, but I can't figure out how to make the widths graduating from smallest at the top to widest at the bottom. I don't want to have retaining walls (I tried that method anyway and couldn't manage to make it work) and I don't want to use the flare/curve stairs tool because I want them to progressively get wider as one descends, not flare out at the top or bottom. Thanks! I'm using x10 premiere. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 6, 2018 Share Posted July 6, 2018 I would then use custom slabs for the steps, they are easy to shape and control. DJP Link to comment Share on other sites More sharing options...
Chopsaw Posted July 6, 2018 Share Posted July 6, 2018 If you create an invisible room you can use the winders option in the stair DBX. Just need to be sure to increase the "Max Tread Contraction". 1 Link to comment Share on other sites More sharing options...
