## installing lattice ##
mikesmith
I have an existing house that the owners want to demolish the cement block stair and landing for their main entrance
I am going to put a  new 5'x8' landing with 4' wide stairs …. it is about 40" from ground to the main floor.
I want to put diagonal lattice around the bottom but I cannot figure out how to install the lattice with Chief
can anyone point me to a help video or the correct tool / sequence  to make this happen  ?
Really depends on how accurate you want to be and what types of rendering techniques you plan to use.  You can use a single layer wall type with a lattice material or—my preferred method—you can use primitives.  Just make one big piece of lattice for yourself using solids, block and add to your library and then in the future, just drop into your plan and use boolean operations for all future instances.  Very flexible and accurate.
