Roof & Parapet Walls Issues
ACADuser
Having a heck of a time getting this remodel roof to cooperate.
I'm not using a 2nd floor so I can model the trusses with a slope.
The existing plan is included so you can see what I am working from.
Basically removing the existing flat roof & ceiling & adding parapet walls to raise the family room ceiling.
Adding a porch & rear facade. The existing roof planes will be extended to the new parapet.
The problem I'm having is the interaction of the walls/room below & the parapet walls drawn on the attic level.
See section S3 for intended truss design
Any advice would be appreciated.
Thanks
Belle Vista.zip
Belle Vista Existing.zip
Here's the simple way to solve this:
  1. Create your Roof Plane over the 1st Floor
  2. Add a 2nd Floor with no Roof or Ceiling and no Floor Below
  3. Set the 2nd Floor Height to 30"
  4. Select the Parapet Walls and designate as Solid Railings with a Wall Cap and a Wall Height of 24" (<30")
The attached pic shows the result.5b311a553ea7b_ParapetRoof.thumb.JPG.4c78d1ba004a2cad13163159766f1789.JPG
Note that the 2nd Floor Height and Parapet Height may need to be different for your plan - and you may need to edit one of the walls to be lower than the top of your "Flat Roof".  But the procedure is the same.
I call this method "Parapet Room/Roof"
  • 2 months later...
