Doug_N Posted June 24, 2018 Share Posted June 24, 2018 What is going on with this? The little downward part in the circle is how the whole rafter should look. Why the notches out of the rafter above and below the circled part? Alternate Three - Column.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted June 24, 2018 Share Posted June 24, 2018 Hi Doug, You have a very interesting condition going on with your plan file and for some reason you have some interior rooms set to "Use Soffit Surface for Ceiling". This is causing the bottoms of your roof rafters to be shaved or trimmed off at the soffit level. Hope that gets you back on track. Link to comment Share on other sites More sharing options...
Doug_N Posted June 25, 2018 Author Share Posted June 25, 2018 After changing all to flat ceiling over room I still have the notches. Aaarrrgggg!! Link to comment Share on other sites More sharing options...
Chopsaw Posted June 25, 2018 Share Posted June 25, 2018 Did you reframe ? Link to comment Share on other sites More sharing options...
