GerryT Posted June 23, 2018 Share Posted June 23, 2018 Here's a Demo video as to how I previously handled keynotes in chief using just macros. I decided to show for comments. if you like a particular feature or not you might want to submit a comment to chief now so that it gets considered when they implement keynotes in 'who knows' future revision. Keynotes in Chief architect 2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 23, 2018 Share Posted June 23, 2018 Thanks Gerry, I still use the old plant schedule method. Link to comment Share on other sites More sharing options...
MarkMc Posted July 31, 2018 Share Posted July 31, 2018 On 6/23/2018 at 6:26 AM, GerryT said: Here's a Demo video as to how I previously handled keynotes in chief using just macros. I decided to show for comments. if you like a particular feature or not you might want to submit a comment to chief now so that it gets considered when they implement keynotes in 'who knows' future revision. Keynotes in Chief architect Expand Just found the time to watch both videos, very useful. Have time scheduled this week to finish off the cabinet pricing stuff and think I can use some of this there. I also see a use for this with drafting clients but even more for the construction notes. May try to blend with the plant note thing which gets a little out of hand in the library with multiple clients each with different needs. Link to comment Share on other sites More sharing options...
sst4u2 Posted December 20, 2018 Share Posted December 20, 2018 On 6/23/2018 at 6:26 AM, GerryT said: Here's a Demo video as to how I previously handled keynotes in chief using just macros. I decided to show for comments. if you like a particular feature or not you might want to submit a comment to chief now so that it gets considered when they implement keynotes in 'who knows' future revision. Keynotes in Chief architect Expand The link provided is no longer working. Would you mind sharing the video again? I would appreciate knowing more about Keynotes in CA. Link to comment Share on other sites More sharing options...
GerryT Posted December 20, 2018 Author Share Posted December 20, 2018 Was Removed because of a general lack of user interest and Chief's support for macros. I am no longer recommending macros in Chief but you may want to contact Michael or Joe who have simpler solutions. Here's new link if your still interested. Keynotes 1 Link to comment Share on other sites More sharing options...
CARMELHILL Posted December 20, 2018 Share Posted December 20, 2018 I built an extensive library and system for key notes, without macros. Not all of us are Ruby wiz kids. It surprising how many options there are within Chiefs schedules that use can use. I was using it for mostly commercial but I've started using for my residential. Michael gave me a lot of ideas for this that I've tried to incorporate. I'll post a video later today. It gets a little convoluted when you try to use it on sections and elevations because of the way labels populate in those camera views. I'm hoping fingers crossed that we get something better in the next Chief. A good notes system like what Vectorworks has can be used and implemented in stages..... 1. notes management and easy updating or maintenance of your notes database. Just placing your notes (without keynotes) all over your plan is easier. 2. Keynote implementation with a keynote schedule streamlines annotations for 1/8" plans like in commercial work. 3. Using keynotes for details is less economical because the notes are usually directly next to the detail in layout space. So keynotes arent needed. But users with a mechanical drawing background will still use them here such as when the to exploded parts views. Not really applicable to Chief. 4. Using a schedule of keynotes could have an additional column in the note schedule for code refernce numbers or even referencing into the detailed spec book. 5. Universal layout file not updating....imagine you need to update every note where you changed the wall insulation R value from R-13 to R-21. Chief can do this manually with it's find properties tool, but a good notes database or keynote system makes one change easier to implement across all the sheets. If you use the tools we have now with schedules, you can click the line of the schedule, then find in plan, and you can update the note that way. It works, has probably too many steps, but it's manaeable. Link to comment Share on other sites More sharing options...
CARMELHILL Posted December 20, 2018 Share Posted December 20, 2018 Here's my video of how I do keynotes. I've stopped using them for structure (joist, rafter, and collar ties spans), but I use them for everything else. 1 Link to comment Share on other sites More sharing options...
sst4u2 Posted December 21, 2018 Share Posted December 21, 2018 Well done, Thank you! Link to comment Share on other sites More sharing options...
