mcrump Posted June 7, 2018 Share Posted June 7, 2018 Anyone know an easy way to create a brick window surround. The windows are 3'-0" x 7'-4" round top. I think I have the pre-cast keystone and the rowlock sill figured out but the sailor course going up the sides and over the top has me stumped. The example posted shows the problem with the orientation of the brick. It doesn't need exact detail. I just need it to look decent for a fly-around rendering. Any ideas most appreciated. Windows.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted June 7, 2018 Share Posted June 7, 2018 I think to get it to look right you will need to use a symbol or psolid with transform and replicate. Here is a detailed tutorial but be aware there are shortcuts : https://www.chiefarchitect.com/support/article/KB-00797/creating-a-soldier-course.html Link to comment Share on other sites More sharing options...
Chopsaw Posted June 7, 2018 Share Posted June 7, 2018 It would be cool if a Polyline Distributon Path would work in elevation view but it does not seem to work for me as it seems to let you go to the trouble of setting it all up but will not display in 3D. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 7, 2018 Share Posted June 7, 2018 You might also try a molding symbol. Link to comment Share on other sites More sharing options...
