Catalogs
imagekit
Go to solution Solved by imagekit,
  • Solution
ok i am very new.  how do i import the catalogs? and a more pressing question , i have drawn a glass screen in for my shower,now when i use the eye dropper to tile my walls the screen gets tiled as well. i know the glass screen is just a wall and i have tried using wall break.
thanks
Based on your other post, I assume you already figured out the wall versus room material issue.  It's a good idea to keep your questions on topic so that threads don't get "hijacked".
As for importing catalogs, If you download a CALIBZ file from the Chief web site, you can import it using the "import library" tool in the library menu.  You can also drag the library file and drop it right on Chief.  I think you can also just double click or "open" the library file to import it.
