DOOR HARDWARE
raltd9245
I'm not sure if I'm missing something or is Chief when it comes top door hardware. I just looked for pocket door hardware and did not find any in the Architectural Libraries.
i find handles and locks for doors but no hinges or pocket door hardware. Can someone help or Is this lacking in X6.
Here are Gene's instructions copied from the retired forums:
"Got a solution. Install the flush pull in the door in Sketchup, and then save and import the .skp symbol, with its pull already there.
Put your pull on the L side of the door to make this work right, as shown in the overhead view of the .skp model.
Hey, Chief, fix this, will ya? Pocket doors need pulls, and while you are fixing it, add a couple of different kinds. One, the kind that wraps the edge of the slab, another, one that installs flush into the middle of the face of the stile. We know you cannot recess them flush into the door, but you can surely fake something."
Original thread: Pocket doors will not display hardware - X6
The link may break when CA updates the web address for the old forums.
